Overheating damage?
Bob Bedinger
2003 50hp Johnson sucked mud ,overheated badly, cleared to steam and then to normal telltale flow-- idled fine. Without ever turning off engine, on attempt to come up on plane,the motor stuttered and would not reach an adequate rpm. Idled home 30 mins with all attempts to increase rpms resulting in same limitation.
Spark plugs ,wiring and powerhead all "look" ok.
Haven't been able to sea trial again to see if turning off ignition made any difference.
Was this the overheating protection rpm limiter? Does turning off the ignition reset it? Or is it more likely that I've blown a head gasket or caused other damage. What tests, what remedy(s)? Thanks Bob
Re: Overheating damage?
as WBW, stated in the locked post, check compression, could be just a head gasket, also could be the slow speed didn't reset. watch the water flow, could have eaten impeller.
