hkeiner
Thread starter- Joined
- Oct 17, 2006
- 1,055
HI,
I want to use Seafoam and Deep Creep on a motor that was never decarbed before. It is a 1996 Mercury V-6 150hp oil-injected carbureted motor with 270 hours on it.
I have read the manufacturer's directions and read most of the threads on how to best use Deep Creep and Seafoam. However, I am not able to readily follow most of the suggested methods due to various limitations that I have.
These limitations are:
1) I don't want to spray the Deep Creep into the carbs while running the motor on a hose (muffs), as the boat is stored at a place where I don't want to have the motor smoke like crazy and make a mess at the storage location..
2) I don't want to spray Deep Creep into the cylinders prior to launching the boat on the water, as I don't want to have the motor smoke like crazy in the boat ramp area.
3) I don't want to spray Deep Creep into the cylinders out on the lake, as I don't want to shut down the engine and take the plugs out while out on the lake. Doing so is awkward and I don't want to risk having to paddle back to the boat ramp if I have engine starting problems after treatment.
4) I don't want to put a heavy dose of Seafoam in my regular fuel tank, as it is a 22 gallon tank and the fuel gauge is not very accurate. It would be hard to control the precise ratio of Seafoam to fuel mixture in this tank.
Because of these (self imposed) limitations, this is what I would like to do:
A) Spray Deep Creap into the carbs while the motor is idleing or cruising at low RPMs out on the lake. I plan to use several cans, but not spray too quickly to avoid killing the motor or causing too much smoke at one time. I don't want to kill the motor as I fear it may not easily start up again without removing and cleaning the plugs. I also understand that one should not run the motor at high RPMs with the top cowl and air deflectors removed in order to avoid a "too lean" condition.
B) Replace the air deflector and top cowl and then hook up a 3 gallon reserve fuel tank to the motor and run a strong Seafoam mix (say 1 bottle of Seafoam per gallon of fuel) and run the motor at low cruising speed or WOT until the 3 gallons is pretty much used up. I would, of course, switch back to the regular fuel tank before the carbs go dry.
Would the above described decarb procedure achieve enough decarbing of the motor to make it worth doing or would I be wasting my time or potentially damaging the motor to do it this half-xxx way? Basically, I am looking for a way to either decarb slowly on land without making a lot of smoke and mess (which I figure is not possible) or doing it slowly out on a remote section of lake.
Thanks for any input.
Hal
Hal
