bayliner19
Thread starter- Joined
- Jan 5, 2006
- 56
I have a pre-owned subject boat and somewhere along the way someone has removed the little red indicator light above the tilt trim switch that is unlit until the stern-drive is raised and it then lights up to indicate the drive is not all the way in the down position. I would like to replace this light but cannot find the wire that connects to the worm gear relay. According to the repair manual wiring diagram this should be fairly easy, one side of the light connects to the live side of the ignition switch when in the on position and the other side of the light connects to the green & yellow lead from the worn gear relay. I have tried testing this by connecting a test light to the positive side of the battery (emulating the ignition connection) and then touching the lead from the worm gear relay while manually pressing and releasing the push rod retaining pawl on the stern drive. It should light when released and be dark when depressed, but it just lights all the time. From the looks of the worm gear control head, it appears that it may have come off of a 280, I think most of these were interchangeable anyway. Any suggestions or ideas?When I was young the fish were so big we had to fish from shore with a tow truck line.
