hello all.
I have an 80's sylvan..with an early 80's Johnson 70-hp outboard. This boat has been to the marina twice for repairs since my ownership a year ago....they replaced the exterior fuel line and primer ball...cleaned the cabrs..fixed a broken midjet tube...it has yet to run decent for me...today it wouldnt even start....i switched fuel line over to my kicker motor (a 60's Johnson 18hp) which has always started in 5 pulls.....it took close to 50 and full choke... to keep it running we had to pump the primer ball....it would get hard and then slowly lose pressure....took the boat home and checked out the existing (non replaced line) from the transome metal )double sided barb fitting) to the factory tank....it looked OK...but we bypassed it anyway and ran the fuel line directly to the tank....(so it went tank>hose>primer bulb>hose>fitting>motor......)...the bulb still wouldnt get rock solid.... the fitting secure the hose to the bulb and barb are super tight (fixed banding clamps)..the hose and bulb are brand new...the tank is half full..... I pulled the fitting (threaded male nipple to 90 with plastic pickup tue and small metall intake/screen mesh...had gas 3/4 way up it)- that looked fine..... what can I do now? I am ratehr sure the probem is between the fitting that connects the fuel line to the motro and the tank pickup...I am not looking to buy another fuel line steup (or tank)..but I have a useless boat......when it did run last year it was starving for fuel (especially before repairs)...the vent is not obscured......I am losing my mind here.....any and all help WILL be graciously appreciated...thanks
-garrett
garrettt@rochester.rr.com
-garrett
