ziggy
Thread starter- Joined
- Jun 30, 2004
- 7,473
i'm gonna need to do something with my steering too. it aint broke, yet. i do feel the gears while turning though (the gears in the r&p i think). got me a det-mar rack & pinion system. think it's a det-mar 500, though i'd have to go look again to be sure of that statement.
wondering if i got this right. generally speakin. is the cable attached to the rack and non removable? any chance i can remove the rack for serviceing or just R& R the R&P assy. w/o doing the cable? seems like i just feel the gears meshin to much. i see an adj. screw on the back of the pionion gear shaft. though i only feel it's for adjusting the tension of how hard ya have to turn the wheel. seems like i need to adj the depth of gear mesh or lub it up maybe. this det-mar 500, if that's what it is. has a round tube to house the rack (as oppessed to a square tube) with a nut at ea. end. i assume to dissassemble it. i've not seen 'any' det-mar 500 rack and pionion steering systems anywheres on the www. least nothing that looks like what i got...anybody got any insight for me. ya know, like R&R the whole thing and be done with it. sounds pretty easy to do. don't look to easy to do though. guess i'd rather fix it before R&Rin but certainly want to do it richious as it is the steereing....
i've also not checked the drive end. i do have a little free play in the steerin wheel too. can move it back and forth a bit w/o any reaction from the drive. maybe i need to be checkin back there.......i still suspect the r&p though. mostly cause i can feel what i think is the pionion gear engageing the rack thru the full range of the wheel.........
