Re: Low Compression Problem
So, I took the boat to a mechanic and he confirmed that the motor is in bad shape and needs to be rebuilt. My questions to you are:
All mechanics I talk to estimate 5K to rebuild it. However, I can buy a rebuilt MARINE motor at Pep Boys for $1700 (one year waranty no limit on ussage) and I can put it together myself. Do any of you have any feedback on Pep Boys motors?
I also found a NEW MARINE motor in e-bay for $3500 + shipping. Here is the description of the new motor:
It comes complete with the following :
New sheet metal,New Harmonic Balancer, New Mechanical Fuel Pump
New Ignition System, Marine 4bbl Rochester Carb, New Fuel Line,
New Spark Arrestor, New Flywheel, New Spark Plugs, New Circ Pump.
New 4bbl Intake Manifold.
This is is completely Dyno-Tested and ready to go !!
Manifolds and riser can be added at additional cost.
Starter and alternator available also at additional cost.
I'm just having a hard time wrapping my head around $4500 to $5000 to rebuild my motor when I can do it for so much cheaper.
Any help will be appreciated!!
Thanks.
