I live in the south and fish all year round so I don't winterize. I noticed that it is suposed to get below freezing in my area tonight so I went to do a gear lube inspection. My lube is a little cloudy but still clear enough to be what I'd consider not milky. My question is at what point do you consider that the oil has enough water to cause damage to the case in a hard freeze? I have had water in the gear case on other motors that I have owned where pure water trickled out before the oil flowed when draining and also experienced dificulty shifting. This particular motor shifts fine and had no pure water drain when I removed the fill plug. Any info? I will do what ever it takes to keep things in good shape but I really don't want to have to drain and fill my lower unit after each outing throughout the winter if the slightly cloudy oil is normal. Thanks!
