trouble w/ acceleration 1977 115hp rude
chazamerica58
done alot of searches on the forum for the problem i'm having.
my problem: idles fine, goes into gear fine, when i go to powerup it bogs down around 2000 rpms.
what i've done so far: done compression check (okay). spark on all 4 cyl (okay), trigger assembly moves freely, check all fuel line connections (all tight), recently did a decarb about 2 months ago and replaced plugs at that time, plugs look good when pulled showed some carbon and were wet.
i'm down to the prop. how do i tell if i have a spun hub? i pulled it off and doesn't show any sign of melting. when i had the prop rehubbed about six months ago i noticed the guy who rehubbed it he put a punch mark on the brass hub in line w/ a punch mark n the prop. it is now not lined up but it's only about a 1/4 inch off.
any other suggestions would be appreciated cus i hear the fish calling me!!!!
Walker
Re: trouble w/ acceleration 1977 115hp rude
A spun hub will not give the symptoms you describe. Fouled carburators will.
chazamerica58
thanks walker, i'll take them off tomorrow and let you know what i find!!
sounds like it's flooding out. carbs. if you have a manual check your link & sinc. could be the carbs and spark are not working together.
chazamerica58
well i took my boat out thuis morning and only change was i put my old aluminum prop on and danged if my boat ran fine. i'm stumped!!!! if i had a spun hub on my ss prop wouldn't my rpms rev up?? anyhow i dropped my prop off at my prop guy and he's gonna check it out. your guess is as good as mine!!!
Walker
Yes, they would.
maybe the gunk in the carb finally moved.
chazamerica58
ordered carb rebuild kits last night. not taking any chances. i want my boat running good for crappie and bass season. thanks guys
