Painting Outdrive
FreeBeeTony
Is it to early to paint the outdrive with anti-fouling paint if I am going to launch in May?
Just thought it could be something I could do in my basement.........while waiting for spring...:)
Don S
Re: Painting Outdrive
Depends on the paint. Read the instructions on the can. IF there is a max time before being put into the water, it's usually noted.
It is a paint specifically for aluminum and outdrives isn't it?
FreeBeeTony
Yes Don........it's the correct paint.
Will have to check the can........need to pick up more.
Thought someone might know off the top of their head.
Don S
They might, if you had mentioned what paint you will be using.
FreeBeeTony
Don, you really need to lighten-up..........go have a beer or something.
The paint is Interlux Trilux 33.
tie_one_on
Hey Tony, there doesn't seem to be any time limit on Trilux 33 before launch. So go ahead, paint away.
FreeBeeTony
Thanks tie.........
I pulled the datasheet down from the internet and it did not mention anything about how long it you could leave it out of the water after it is used.
crazy charlie
Personally,I feel more comfortable painting within a week of launching.I am also jealous that Tony has the time to be doing this kind of stuff now.Nothing like getting a jump on the to-do list.Charlie
FreeBeeTony
You have to focus Charlie on the real priorities..........:)
rojoc
I too am going to paint my outdrive. What made you decide on that paint? Thanks, Neil
stevieray
Neil - that is the best antifoulant paint to use if you keep the boat in the water. It is designed for use on aluminum - unlike most bottom paint. If you don't keep it in the water, you would want to use a glossy paint like new ones have.
