AMD vs Intel Processors
BRG25
I'm helping a friend in college with limited funds upgrade his computer. I used to work for a shop building machines but I'm a little out of the loop when it comes to the new processors.
Looks like the Athlon XP 2600+ is the rough equivalent to a P4 2.8GHz. Is this correct? I'm not looking at any of the 64 bit processors. There are about a billion web sites with CPU Statistics and my eyes are glazing over. I've been checking e-bay and pricewatch for the best bang for the buck. What say you IT guys?
Tail_Gunner
Re: AMD vs Intel Processors
Just a few question's, do you intend a motherboard uprgrade, if so what type of video card aka agp or pci, is this comp just a web browser or will there gaming or video encoding.........what type of ram do you currnetly have and perhap's a dollar figure for your project might be in order.......to your orignal question xp vs p4........p4 no question
BRG25
I'm just looking for opinions on processors (around a P4 2.8 probably). No gaming. I will purchase a motherboard and RAM based on the CPU. I will reuse ATX case, and all drives. I would like to keep it under $200. Thanks.
Gary H NC
Ditto on the P4...The AMD chips run hotter
Asus makes a solid motherboard...been using them for awhile now.
Check a website called NewEgg or ZipZoomFly,They have great prices and free shipping on most items.
Gary H NC
Just looked on NewEgg, They have 3.4 ghz intels for 167 bucks...
Tail_Gunner
There ya go:Qty. Product Description Unit Price Savings Total Price
1 EPoX EP-8KDA7I Socket 754 NVIDIA nForce3 250 ATX AMD Motherboard - Retail
Model #: EP-8KDA7I
Item #: N82E16813123265
Return Policy: Standard Return Policy
Select An Optional Extended Warranty Plan 1 Year Service Net Replacement Plan -- $9.99 2 Year Service Net Replacement Plan -- $14.99
Remove Save Move To Wish List $40.99 $40.99
Desktop Memory
1 pqi TURBO 1GB 184-Pin DDR SDRAM DDR 400 (PC 3200) Desktop Memory Model PQI3200-1024SBL - OEM
Model #: PQI3200-1024SBL
Item #: N82E16820141233
Select An Optional Extended Warranty Plan 1 Year Service Net Replacement Plan -- $14.99 2 Year Service Net Replacement Plan -- $19.99
Remove Save Move To Wish List $95.99 $95.99
Processors
1 AMD Sempron 64 3400+ Palermo 2.0GHz Socket 754 Processor Model SDA3400BXBOX - Retail
Model #: SDA3400BXBOX
Item #: N82E16819104231
Return Policy: Processors (CPUs) Return Policy
Remove Save Move To Wish List $66.50 $66.50
___________________________________________---
Subtotal: $203.48
Shipping
Zip Code: FedEx Express Saver FedEx 2Day FedEx Standard Overnight APO/FPO-Military ONLY FedEx International Economy-PR ONLY UPS Guaranteed 3 Day Service UPS 2nd Day UPS Next Day Saver
*Enter your Zip Code and select a shipping option to determine your shipping cost. Shipping: $0.00
Redeem Gift Certificates
Claim Code:
Security Code:
Gift Certificates: $0.00
Apply Promo Code
Promo Code:
Total(before tax): $203.48
IMPORTANT SHIPPING INFORMATION
All orders require 1-2 business days of processing time prior to shipping.
The above system is far faster than a p 4 system and cost's quite a bit less, dont let that Sempron cpu fool you it's as fast you'll ever need.
One last note this system is 64 bit ready and faster than most p-4's........Good lick ....As to the ram check out the lat timing's that's good ram.
tommays
I would say which one is better changes ALL the time and that for 99% of the users would never know the difference
With the intel the best right now after a long period of better AMD STUFF
Tommays
BRG25
I've had good success with both Intel and AMD. Like has been said...AMD's tend to run hotter but they're also cheaper.
Tail_Gunner
Tommays
Agreed for maybe 2 years amd had the better priced and faster cpu,today intel proc's have the edge. However that applies only to gaming, video decoding or some type of graphic intensive program.
That little Sempron is @ 50.00 and will outrun most any p4 running and being a venic core it will generate very little if any heat. The reason i led with that proc is it fit's his budget nicely, will run any app he chose's, it's fast enough to run any game and the user may go to a 64 bit OS any time he or she choose's
Now if he has a any inclination to tinker it can probably overclocked to 2.5 to 2.7, in it's present form its' faster than a 2.8c and by far cheaper.
The Proc's he is refering to are truly dated but still very good for alround use, keep in mind that's a 3400 semp and not the 3100 reiveiwed in the following article.
http://www.xbitlabs.com/articles/cpu/display/sempron_7.html
i386
Use and like both. Using an Athlon XP 2800+ at the moment. It had the most bang for the buck when I bought. I also highly recommend Asus motherboards and Corsair memory (even the cheap stuff).
Newegg!
I don't see where it really matters which processor "runs hotter". If you buy the boxed processor it'll have a heatsink & fan designed by the manufacturer. It will cool the processor sufficiently in either case. It's importation to have proper case ventilation too. 1 sucking and 1 blowing case fan should do it.
Tail_Gunner
there ya go, i hope i havnt taken the magic from your selection, but the above described componet's will rock...errrr crunch number's way beyond your freind's expectation's and your's.
BRG25
Thanks for the suggestions guys...just what I was looking for.
KaGee
I've always felt AMD was more bang for the buck. I've never had a heating issue, and I'm on my third AMD set-up. I've got the same chip as 386. Even when I overclocked it, the heat was well within tolerance. I also have a very good ANTEC case with 2 large fans to move the air.
