crash-proof
Thread starter- Joined
- Apr 8, 2006
- 16
Hi, I have a Bayliner 160 powered by a Merc 50.
Every time I head out I check the "pisser" and it flows OK. However, last week I got the dreaded horn (more like an annoying alarm clock buzz on mine). I shut down the motor for a few minutes, restarted and got the horn again. The water was flowing out of the pisser, just not as fast as usual. The temp of the water was lukewarm, which led me to believe that the motor was not overheating. I continued back to port with the horn blaring, and the motor ran just fine. (it was only a 5 min journey back).
Could it be that the thermostat is worn out and giving me false readings? Or the actual horn is shorted out? (the horn is located somewhere behind the dashboard).
And what is the easiest way to improve water flowing thru the engine? It could be that there's sand clogging it up. I certainly don't want to risk taking it out again and overheating. Is there some type of "plummer" snake that I can feed thru the pisser?
Thanks in advance.
Thanks in advance.
