Harold T. Yates
- Joined
- Jan 8, 2007
- 2
Engine has not been run much in the last couple of years. Starts and idles good, but once you put in forward or reverse the motor dies. Before I put the houseboat in the water you could put the motor in gear, forward or reverse and the motor would continue to run. When I put it in the water, started the engine, the motor cut off instantly once the prop had force against it. Any suggestions? Thanks! Harold T. Yates
