Re: water press readings. Tried teeing into pisser hose but not enough press there to get a reading, at least with water going overboard through hose. Some one said to go to other side of engine and remove small plug and tee in there. If I do that assune I use a brass L fitting in place of plug and run hose off that. Do I need to drill hole through base of engine in order to run hose or is there a better way? Also any trick to removing that plug, use heat first?
Re: temp gauges. How do I hook up temp sender on each head? Understand there is no plug to remove in which I could thread in sender. Do they make a sender attachment of some sort that will work?
Re: trim/tilt rocker control at motor. Would like to add one and assume I'll have to drill appropriate hole through case?
thanks
thanks
