need heip with omc model # on drive
rusty bolts
model 985680 serial T0237380 is this a v8 drive the #s in my seloc book do no match up . is this a king cobra drive 460 ford thanks JD
Lyndy
Re: need heip with omc model # on drive
Where did you find the 985680? Is the Engine an OMC Engine?
rusty bolts
somone gave me the # from the unit they are selling,it must be wrong .i think off a 1993 460 omc ford ?
Lyndy
The following from the BRP.COM Website. Newer OMC Sterndrives have codes that tell a fair amount of information. Below are model numbers for 1993 and 1994 7.4L and 8.2L
1993 7.4L
744CPEJVB
744DPEJVB
744DPPJVB
1993 8.2L
824BPEJVB
1994 7.4L
744DCPMDA
744DCPMDM
744DDPMDA
744DDPMDM
744DGPMDA
744DGPMDM
744DJPMDA
744DJPMDM
They do have the same style format. I suspect this is what you may want to be looking for. Since I am new on this board, if I am not correct about this, they will let you know in short order. Damn Officers!
Boatin Bob
985680 is actually the model # of the transom mount for 1989 Cobra's. A complete system is made up of 3 pieces, the engine, transom mount and the outdrive. Each piece has it's own model # and serial #.
Gary H NC
On a cobra drive there should be a ID tag on the upper housing,port side about 2 inches above where the lower section is..Should have model and serial.....
