Hello all, glad to be here.
I have purchased a 1986 Procraft with 86'Rude 90hp 16.5' from my dad. I'm very familure with the boat as I have probably put more hours on it than him. He bought the boat in 89 and has been garaged all its life and is in excellent condition.
The boat has been sitting up not used for almost 3 years being cranked every now and again. I have changed out the lower unit seals as they were leaking. Also while I was there changed water pump. I have carb kits,plugs,choke cover and valve(was leaking) and new fuel and water hoses to replace. The compression on the motor was 105psi in each hole. I have drained all fuel out and will flush once carb kits and hoses are installed.
My question is can you guys think of anything else I need to look at before i put her on the water? Is the compression worthy enough to keep running b4 rebuild?
Another question, she runs out about 46mph with 2 people @ about 5400 rpm's. I'm not sure what pitch the prop is (not labled, assumming stock stainless OMC) but it gets out of the hole good. What would a jack plate do for me about 4" worth? I would like to see more speed and a few more RPM's.
Thanks in advance for your help, dean
