Which is more important in selecting a prop, cruising speed or higher WOT RPMs? Should I sacrifice cruising speed for higher WOT RPMs?
My Yamaha F115 outboard has a recommended max range of 5000 to 6000. Here are the results of my recent test. These are all 4-blade props.
Solas Aluminum 17" pitch:
cruising 4000 rpm @ 25 mph
WOT 5600 rpm @ 39 mph
Powertech SS 17" pitch:
cruising 4000 rpm @ 29 mph
WOT 5300 rpm @ 40 mph
Powertech SS 15" pitch:
WOT 5800 rpm @ 40 mph
A 4-blade prop was recommended because of the weight of my Sailfish 1900 Bay Boat with a full tank of fuel, 2 adults, and F115 Yamaha is about 3000 lbs. The only Yamaha Performance Bulletins I was able to find for the F115 on a similar boat and weight used 3 blade props.
Would it benefit me to use a 3-blade prop to try to increase WOT rpms to 6000? How would performance likely be affected coming from a 4-blade?
