How big a job is this? My mechanic suggests the water pump in my 93' johnson 150 be replaced. The impeller is probably shot (at a minimum). The engine overheat alarm went off last time I had the boat out. This happened after I hit a sand bar at high speed. Tried to flush out the sand, but the overheat problem continues. There's some water discharge from the engine when I connect the ears, but maybe not enough for the top cylinders which are heating up the most. Mechanic suggests the job could take me-a beginner-4-8 hours, I may need at least one person to help me, and the job can be dangerous (weight of lower unit, possible need to turn drive shaft to make things fit back together, etc). If you suggest I take on the job, what's the best reference for doing this work?
