ARE THE FLOATS CORRECT PICS INCLUNDED
gustafsonerik
OKAY I KNOW THIS IS A SHOT IN the dark..75 merc 500 wont go over 6mph all people were talking if the floats were correct on iboats..so heres a pic maybe i screwed it up some how when i rebuild the carbs maybe you guys will be able to tell by the pics thanks Erik
Laddies
Banned
Re: ARE THE FLOATS CORRECT PICS INCLUNDED
It's not off enough to cause a problem but inlet on the top right should be set like the one on the left
gustafsonerik
could my lower unit have anything to do with this problem
Plainsman
Do your RPM's stay high, while the speed is slow? Or are the RPMs low as well?
gustafsonerik
the rpm's seem low also i don't know if this has anything to do with it but i took out the electric choke mechanism and i only use the manual one thanks Erik
gustafsonerik
the rpm's seem low also i don't know if this has anything to do with it but i took out the electric choke mechanism and i only use the manual one thanks Erik also when u rev it with the warm up lever it goes high but not in the water
Plainsman
The reason I asked is you mentioned something about the lower unit. IF the RPM's stayed up, then it could have been a spun hub on the prop.
Did you make the adjustment as Laddies suggested? Does priming the bulb while it's runniing change anything?
Have to checked spark and compression?
gustafsonerik
comp.spark all good priming makes the engine stall erik
Capt Ken
Have you checked to be sure the timing arm is advancing?
Laddies
Banned
Priming really shoud not make the engine stall, have you cked. the fuel pump diaphram
gustafsonerik
fuel pump diagram looks good no tears if i had a bad one wouldn't it get better if i squeezed the fuel primer..like rev up ??? also would the stator or the electirc apratus under the fly wheel have anything to do with why it only goes 6mph ?????? thanks Erik
comp 115 110 105 125
gustafsonerik
also i've been driving the engine without the cowl and the top on .. would that need to be on for some reason thanks Erik
j_martin
Squeezing the primer with reasonable force shouldn't change the motor operation. You might have bad needle valves, or crud in them.
Is it straining trying to go, or just not trying?
Plainsman
Have you cleaned and rebuilt all the carbs? Do you have a manual?
Laddies
Banned
Eric after you have cleaned the carbs makeing sure the high speed jets are clean and have confirmed that the spark advace is working (35 degrees at WOT) that only leaves the high speed winding in the lighting energizer if you need to ck that we can give you the OHM readings. (380 to 420 ohms on the low speed and 9 to11 on the high)
gustafsonerik
laddies thanks i really appreciate it i'll clean it tommorow and take her out thanks again Erik
