Re: 25 hp mariner...... intermitently drops a cylinder??
UPDATE--------------> I launched onto the mississippi river for a goose hunt that was about 8 miles downstream.........the motor fired up and ran perfect all the way to the spot. On the first retrieve with the boat......it ran fine all the way to shutdown....around 10 minutes running time. On the second retrieve.....about 1 hour later.......it fired up with the dropped cylinder again. At that time I took the cover off and disconnected the black/yellow wire. It continued to run....on 1 cylinder....but kept running. I assume that I should rule out the killswitch circuit by this test. It eventually hit a shot and shortly thereafter.....fired up on both cylinders.
It seems to refire up better at lower rpm's...although it has regained the cylinder while at full throttle. Travelling upriver requires at least 1 cylinder at full throttle to outpace the current...hehehe:%
As I have been using the mercury express parts page....... I can see that the stator is broke into 2 pieces.....and while replacing the trigger recently I saw it for my own eyes. Does any of these details give some clue as to which piece or both need to be tried?
merc.dog
hey frist do a plug reading wet or dry when eng.drops out
When in the "dropped cylinder" mode I did pull the affected plug out to find it moist....not dry.....not soaking wet....but just moist.
Also....if I have to replace the stator......my motor did not come with a charging feature that would be killer to replenish my battery......is it possible to add this feature which was once an option or feature? I think I was told that the stator is where it is located from. Would that require a different stator or am I confused?
Fellas......thanks for your help...... I love the motor........and I am confident that with as much appreciated knowledge you guys have....I can once again enjoy it's reliability.
