Re: 1992 30 hp evenrude striped fill plug
Been a Machinist all my life, but sometimes I can't figure why people give advice that is a "well, try this"., or whatever, without know the properties of all things metal. R. Johnson has one fix. What i would do is simply take some JB "WaterWeld" putty, fill the hole up and sand smooth (need a nice, oil free application). What threads are left will see it there for life. Somewhere in the same area (just above/below/side-tap the metal for a clear ring so you don't go into a bearing support-need to see the case myself to be sure) do a 1/4 drilled hole, drill stuck in grease to hold the chips. Now do a 1/4-3/8ths countersink and spot the case for the new o-ring or washer. re-drill (grease on everything again to hold chips), with a "F" drill, and re-tap 5/16th. Round head 5/16ths screw, oring, little blue Loctite....done.
