HLongcrier
- Joined
- Jan 18, 2007
- 5
Motor was running like a top and cranking on first pull all day. I reached my duck hole and shut her off. When I came back a couple of hours later, I pulled the string and she fired off fine. After about fifty yards, the motor choked out and she hasn't run since. I changed plugs and they seem to be fine. Traced all the fuel lines from tank to fuel pump and fuel is getting to the fuel pump, but it doesn't seem to be going anywhere from there. I changed the fuel pump (no pin holes or anything seemed to be wrong with the old one, but I changed anyway) and still same result. She fires on first pull when starter fluid sprayed in the carb, but will only run on the amount of fluid sprayed. I have a feeling cleaning the carb will be next step but just wondering if some other part that I'm ignorant to would contribute to the prob. I'm new to the forum and would welcome any advice. Motor did this to me last year but after shutting off for an hour or so it would run fine, like nothing was wrong. Thanks again.
