seven up
- Joined
- Jun 4, 2006
- 275
Re: Phone installation gurus
was re-reading your post #231. Can you disconnect the underground service wire from the "naked" circuit board and re-connect without destroying the device ??? Depending on your type of outside junction box this may be the "test service unit" that I was writing about.
I am only continuing with this because you are obviously capable of working on the system from what you have described in your posts.
By going straight-through the ouside junction box with only a splice directly to your inside wire you'll find out if the "naked" circuit board was the culprit. Just make certain everything can go back to the original schematic. More $$$$
Enjoy
Enjoy
