96 Suzuki shaft length
offshore99
I have a 96 Suzuki DT140. I have found that there was a 20 and a 25 inch shaft length. How do I find out what shaft length I have?
My serial # has numbers only. It is 14002651273
JUSTINTIME
Re: 96 Suzuki shaft length
u need the model number
or measure from the top of ventilation plate to bottom of clamp bracket
offshore99
I don't know the model #, it looks like 25 inch measuring where you said. How does a 95 Suzuki DT140 with a frozen flywheel and a good lower unit for $300.00 sound to you? It has good carbs,starter,plugs,power pack also. I can use the lower unit to replace the one on my 96 DT140.
Thanks
JUSTINTIME
lower unit alone is worth $500
frozen flywheel is usually a seized motor maybe
offshore99
Thanks-I think I'll get it and use it as a spare parts motor.
JUSTINTIME
yep the one on the left
bottom of clamp bracket to top of ventilation plate
