evinrude v6 235 how to remove lower unit?
imported_ricardo
i would like to know how to remove the lower unit of an evinrude 235 i have losen the bolts but seems like the shift rod is the only thing keeping it from geting down. how i remove or losen the shift rod so the lower unit comes down or if i have to lose more bolts? i removed all the lower unit bolts 6 in total,
OBJ
Re: evinrude v6 235 how to remove lower unit?
Hi ricardo and welcome to iboats!
You'll have to remove the shift rod lever pin to release the shift rod.
If you look from the starboard side of the engine, behind the bottom carb you will see the shift lever and the shift rod coming up to engage it. You will also see a 3/8 bolt head back there. This is the shift rod lever pin. You can get to it using a 1/4" drive and long extenstion with a universal joint. Unscrew the pin and remove it. The lower unit will then drop off. It helps if you shift the lower unit into reverse....this gets the lever down for easier access. And I would also reattach the lower unit with at least one bolt. Will keep it from hitting the floor once the shift rod is lose......d:)
And....don't turn the shift rod. It's set at a specific height. Turning it will throw the shift outta whack.
Walker
Sounds easy doesn't it. NOT. On the big V6's that don't have a split cowling pan I usually take the bottom carb off. It makes re-assembly a whole lot easier.
Actually I believe the bolt pin is on the port side.
imported_ricardo
thanks obj and walker for the advice as soon as i took the lever pin it fell and also took the lower carb and made it easier .... thanks for the help
mikesea
another hint for next time,using a 1/4 drive,with a 3/8 universal socket and putting some tape around the universal part to restrict the flexing(becomes clear when you do it)put engine in reverse.An extension bar of about 12 inches You can get the bolt under the carb out pretty easy.Removing the shift cable from the linkage helps.a very long needle nose or a grabber tool to pull it out and replace it helpsWhen putting it back together,a long needle nose ,or needle vice grips will help line up the shifter rod by manipulating under the cowling pan,or down below where the shift rod exits the midsection.
