Last Nerve
Thread starter- Joined
- Apr 17, 2006
- 11
Boat is a 1976 Glastron that I was told has been re-powered. Mercruiser 260 ser.# OL364398 with pre-Alpha outdrive. Previous owner had installed a GM HEI distributor (main reason for changing).
When I install the new distributor I know that I have to use the shunt plug to set base timing. When setting base timing do I set to 8 degrees BTDC as called for in engine specs @ 650-700RPMs or is there a degree of advance in the module that I have to compensate for?
Does the spark plug gap have to be changed?
