Re: Mercury 7.5 from Belgium - No water
Thoose are easy to get off. There will be a 1/2 locknut up under the antiventilation plate above the prop. It's in a cavity right next to a round water intake screen. Remove that. In front, you'll see a thin 9/16 locknut. Loosen that in stages as the gearcase disengages until it slides out of the slot. Then remove the gearcase.
Getting it back on is a lot harder. It's challenging to get everything lined-up, but it goes back together in the opposite order. Make sure the water pipe slides nicely into the guide tube.
Merc says to put the shift lever in Forward before dropping it and when reassembling. I personally find it easier to do in Neutral, but I'm weird.
