The automatic choke never did work correctly before my motor blew, I always used the manual choke. Since I've installed a rebuilt powerhead, I've gone ahead and reconnected the choke solenoid in the configuration given by my Clymer and SELOC manuals.
The solenoid, plunger, and spring linkage are there but the plunger spring is not so the plunger does not get pushed back up at this time. I've ordered a new spring and its on the way.
The question that I have is about its operation. I've followed the wiring schematics and the plunger does go down when the choke switch is activiated. But the plunger goes down a little bit when the ingnition key is turned. I know that the choke switch is wired into thermal thermal switch that keeps the choke from fully opening until engine temp reaches a threshold, but is the plunger supposed to activiate at all when the ingnition key is turned and the choke switch is not activated? Of course, the lack of the plunger spring to resist the force from the magnetic field seems to make it close more. Is this behaviour normal for the choke solenoid or do I have a wiring issue?
