Jack Letby
Thread starter- Joined
- Jan 27, 2007
- 5
Ref. : 1966, 6HP Johnson Model "CD23E" Sea - Horse Motor.
Dear Forum.
My 1966 Johnson 6hp motor is hard to start, spent its life as an auxillary, not a lot of running time and no rust. The carburetor has been fully serviced, and it has a good spark. A compression test over about four pulls read : Top Cylinder 60PSI [dry], 120PSI [wet]. Bottom Cylinder 60PSI [dry], 110PSI [wet]
I would appreciate the Forum's suggestions, please.
Also could you advise on the following.
1. The recommended compression value in either PSI or Kg/cm2 for this motor ???.
2. The specification has the Displacement at 8.84 Cu. Inches or 145 Cu. cm. Does this relate to compression ???.
3. Also looking for a website that has a "1966. 6HP Johnson Outboard Tune Up / Servicing Procedures", any suggestions ???.
Looking forward to your assistance, thank you. my email address is < letby@talent.com.au >
Jack Letby. Sydney.
Dear Forum.
Jack Letby. Sydney.
