1996 30hp tiller-remotes conversion
LurcherNZ
I have a longshaft 30hp Johnson 1996 model tiller steer. I am looking at a kit to convert it to remote throttle/gearshift. I have found a kit which fits ES series and later outboards. I have tried to work out whether this kit would fit my motor by web searching but have failed
can anyone help? Should I remove the tiller arm, when I install such a kit?
Thanks in advance
John
New Zealand
OBJ
Re: 1996 30hp tiller-remotes conversion
Welcome John from New Zealand!
Don't believe it's neccessary to remove the tiller handle John but you will need to disconnect the tiller handle throttle cable to connect up to the remote cable.
From where did you get the kit John?
LurcherNZ
From Ebay
do you think it will fit my outboard?
OBJ
Dunno with out seeing it or having some kind of part number to go by. The BRP kit number for your engine from 90' to 96' is 433720. Any mention on eBay of this PN?
LurcherNZ
Sweet!!!!!!!
Yes that is the number quoted. Thanks for your help, this place is a great resource!
Many thanks
John
OBJ
Glad we could help John.....d:)
Don't be a stranger here....there are several other New Zealanders here. Check out Dock Side Chat.
