1981 Evinrude 35hp compression
merc 18xd
Hi
I would like to know the compression specs for an 1981 Evinrude 35hp 2-strokes 2 cylinders.
Ands since it's kinda of an old motor what's the lowest compression acceptable.
Thanx in advance.
OBJ
Re: 1981 Evinrude 35hp compression
Anything above 90psi on both cylinders and within 10 > 15% of each other is considered very good merc. I have had engines run very well on compression in the low 80's and even a little lower on occasion. But the real key is how close they are to each other.
True, when the compression starts getting down below 80, either time for a for a rebuild or new engine.....this in consideration if a good decarbing didn't help and there are no leaks in the head gasket.
