FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
I am looking at buying a '97 Johnson 175 Fast Strike, and the compression readings are #1-98, #2-100, #3-96, #4-95, #5-88, #6-90. Are these readings consistent with its age or does the #5 & #6 reading give concern as to the engines life expectancy?
Thanks for the tip, I will do just that, That would be a logical conclusion! I really appreciate the tip! Going to take it out today and will try the test again!
I have a 98 175 Johnson Fast Strike after the motor has run for 20 minutes it starts to run rough as if it is running on 5 cylinders I changed the spark plugs it didn't solve the problem. Any advise
I just did a compression test on a 96 johnson fast strike 150. Left side 120 middle 118 bottom 100.
Right side top 122 middle 120 bottom 115. The 100 is the lowest cylinder and gave the lowest compression. Should I be worried about it. I'm trying to sell the boat what do I tell them?
