85' 40 hp VRO fuel pump
thurps
I do not use the VRO. Can I replace the broken fuel pump with a non VRO pump?
imported_woody
Re: 85' 40 hp VRO fuel pump
what should i do in buying 115 evinrude is there a certian procedure i dont know the last time it was started
muskrat
go to bpr's web site & look up your model it has both vro & fuel pumps listed........
rickdb1boat
Part number 438556 (About 50.00) will do the job. You will need to do a bit of plumbing with the fuel lines to make it work. Not a hard job....
thurps
Thanks gentelmen; I love this site. I always get good presice information, fast.
Ginder75
I just did this same conversion on my 1990 50 hp. I was chasing down a fuel problem and I settled on the fuel pump. I decided a $50 pump was better than a $50 kit for my VRO.
The entire swap took two hours, with me working at a snails pace, going for parts (forgot to order the plug for the pulse hose), cutting a new gasket by hand (parts supplier could not get the gasket (fuel pump to cylinder case) for a few days.
Now I am waiting on a tilt and trim rebuild kit and a nice day to put the boat on the water.
