Re: 88 XR2 Temp. Guage Sending Unit
You are experiencing the difference in readings between a water temp gauge and a cylinder head temp gauge. You can do one of two things. 1) Using an infrared temp gun, or temp sticks, measure the cylinder head temperature and compare it with the gauge reading. If those numbers agree they will be your reference. The key though, is to determine what acceptable cylinder head temperature is -- and it is NOT the same as water temperature. As I mentioned earlier, the closer to the plug you mount the sensor, the hotter it will read as thats the hottest part of the head. 2) I'm not familiar with the heads on that motor but look for a small plug that can be removed that is open to the water jacket. It will likely be around the top of the head. If the current sensor is not the correct thread size, you can order a proper one or use a reducer bushing availbable at any hardware store. It is important that you measure the resistance at the various temperatures. It may be this is an incorrect sensor for this application.
