Log style manifold conversion
imported_Mugsy
If I convert my 5.7 mercruiser from the log style manifolds to center rise manifolds how do I re-route the thermostat plumbing? If at all !
Haut Medoc
Re: Log style manifold conversion
I think that it would differ if you are raw water cooled vs. fwc........;)
180shabah
Haut, I guess you edited faster than I posted.
wire knot
I converted just as you ask.
Went with GLM center riser.
The water inlet is still in the forward part of the man.
Just added a 90 deg hose fitting to connect to
the therm. housing.
There are other connectors from the risers to the
intermediate housing that were more troublesome.
But longer exhaust hose did the trick.
The folks at ebasic power helped me.
I was able to drive there and get personal help.
Good folks, you can get them on ebay.
Hope this helps.
WK
flashback
what's wrong with the logs? I have them on my boat. do I need to change?
Haut Medoc
Nothing.....
But you will get a little more HP from the better flow & reduced back pressure.......;)
flashback
well I'm glad to here that, I suppose I may try to convert in a few years when I need to change the manifolds, the engine's fresh, but my boat's old like me and I don't ever use the power it has now. I try to stay out of the secondaries, the gas goes too quick..d:)
