Charlie D.
- Joined
- Feb 20, 2007
- 18
Hi all, new user. I have an on going ordeal with my mpi engine. I have to engage the starter for 20 sometimes 30 seconds or more to get it to fire up. I've been searching for the problem but havn't found it yet. I checked the fuel pressure was a bit low ( a couple pounds ) changed the fuel pressure regulator and now the fuel psi is within specs. Didn't help the start problem. The first time I changed the dist, cap and rotor it cured the problem but only for the next half dozen starts. Now the dist. cap and rotor change dosent' really have much effect, still hard to start. The boat was originally put into service in Denver, I live on the gulfcoast, sea level. I contacted Merc and was told that doesn't matter. OK could it be a sensor keeping the engine from firing as it should seeing that the first owner didn't know how to flush the engine and burned the raw water pump up? By the way the pump fryed before any damage could occur to the engine. Sorry for the long thread, just trying to cover everything.
thanks
charlie d.
thanks
charlie d.
