OhioLowell
Thread starter- Joined
- Oct 21, 2005
- 189
Well all I have overcome my fears of the transom. While I was tearing into the boat today to remove the rotting floor I did find some more "ISSUES".
You all know how it goes. Like the mulch where the stringers used to be. That is really the one that has me thrown for a loop right now.
Here are some pics:
This is how the boat started, more or less. I know the boat looks like a heap but I really like and think it has personality.
This is he interior of the boat after the floor was removed. The boards that the floor was fastened to were in pretty rough shape.
This is a shot of the interior after the floor boards were removed (well mostly removed). That black stuff is the stringers, well,,the used to be stringers. They are falling apart and need replaced.
Now I have these questions:
1. How can I replace these stringers? The ribs are made out of fiberglass. I was thinking that once I removed the transom I may be able to slide new stringers into the slots in the ribs from the back of the boat.
2. Do I have to replace the stringers with wood? Is there anyway I can make them strictly out of fiberglass so we don't have the rotting issue again?
3. Once I replace them, then what? (here's what I was thinking, Remove the old stringers, rough up the glass under the old stringers, and on the ribs, slide in new stringers once the transom is off, epoxy the new stringers onto the hull. After the epoxy is set glass over the stringers and the ribs to the hull over each stringer with glass mat.) Does that sound feasable?
This is a shot of the bow where the stringer used to be.
In this shot you can see how the fiberglass ribs are shaped.
That will do it for this chapter right now.
Thanks,
Lowell
Here are some pics:
Thanks,
Lowell
