Help,...I have a V-Max OX 66 150 hp VX 150 LRXZ
10/00 serial # 6J9 L 002072 S
This engine is has approx. 100 hours on it,and was running great then one day it just would not start.I'll tell you what I know and what I've replaced.Firts off there is fuel and spark.But no injector operation.I have installed a brand new CDI unit,the fuel pressure is 35,4 psi.and holds.The main relay is good the crank position sensor is also good as well as the atmospheric sensor and the air intake sensor.These components check out as per the factory shop manual.During cranking the injectors do not make any noise (clicking) I checked the resistance of the injectors and they read 12.6 ohms.I also check the signal supply voltage and it = 6.50 volts.during cranking.(Battery voltage is almost 12.30 under cranking)This was checked at the injector connector The shop manaul does not give the injector risistance spec or the supply voltage for the injector .So with out that spec I'm unsure if it's correct or not.The engine will start and run if I spray starter fluid into the throttle bodies,until the fluid runs out.The O2 sensor checks ok but the engine won't run.Even if the O2 sensor was bad the engine should still run just not good.Any help would greatful,as I'm in the middle of the Exumas Bahamas.So I'm limited.
