tach problem
Benny1963
tach is 1000 rpm off and acts funny mech told me that it could be rectifyer 1981 crossflow also that rectifyer is watercooled and expensive can i test rec with common volt meter sorry about double post on wire size didnt hit new topiic button
thanks so much for everthing
benny 1963
Joe Reeves
Re: tach problem
(Testing Tachometer With Water Cooled Regulator/Rectifier)
(J. Reeves)
A quick check is to simply plug in a another new tachometer as a piece of test equipment. If the new tach works properly and the old tach didn't, obviously the old tach is faulty.... but usually boaters don't carry around a spare tach (see below).
A faulty rectifier wouldn't damage the tachometer, the tachometer simply wouldn't work. This is due to the fact that the tachometer operates off of the charging system and the rectifier converts AC voltage to DC voltage, enabling the charging system. A faulty rectifier disables the charging system, and the tachometer simply doesn't register.
However.... those watercooled regulator/rectifiers that are used on the 35amp charging systems (and some others) bring into play a different type problem, and as you've probably found out, they are really a pain to troubleshoot via the proper procedure. There's an easier way.
The tachometer sending/receiving setup operates off of the gray wire at the tachometer. That same gray wire exists at the engine wiring harness which is connected to the engine electrical terminal strip. You'll see that there is a gray wire leading from the regulator/rectifier to that terminal strip, and that there is another gray wire attached to it. That other gray wire is the wire leading to the tachometer which is the one you're looking for.
Remove that gray wire that leads to the tachometer. Now, find the two (2) yellow wires leading from the stator to that terminal strip. Hopefully one of them is either yellow/gray or is connected to a yellow/gray wire at the terminal strip. If so, connect the gray wire you removed previously to that yellow/gray terminal. Start the engine and check the tachometers operation, and if the tachometer operates as it should, then the regulator/rectifier is faulty and will require replacing. If the tachometer is still faulty, replace the tachometer.
If neither of the yellow wires from the stator is yellow/gray, and neither is attached to a yellow/gray wire, then attach that gray tachometer wire to either yellow stator wire, then the other yellow wire, checking the tachometer operation on both connections.
I've found this method to be a quick and efficent way of finding out which component is faulty.... the tachometer or the regulator/rectifier. It sounds drawn out but really only takes a very short time to run through. If the water cooled regulator/rectifier proves to be faulty, don't put off replacing it as they have been known to catch on fire with disasterous consequences.
Benny1963
Re: tach problem
the mech said it was water cooled but when i look up 1981 crossflow 150 on brp site for it shows small rectifyer 3wires and seperate regulater
if thats the case which one controls tach
Benny1963
Re: tach problem
Joe Reeves
Re: tach problem
Before answering that question, look at your engine to determine what type rectifier you have.
A water cooled regulator/rectifier would be located on top of the powerhead just to the rear of the flywheel.
The smaller type rectifier would be located just to the front of the engine's vertical wiring terminal strip on the starboard side of the powerhead.
Benny1963
Re: tach problem
rectifyer is in front of power strip what color wires come off the rec have one gray wire on power strip
