Mercury 35 Elo
Kansas Basser
Need some help, Mercury 1987 35 hp. OB111440 Model 1035717, this motor is on a 1987 Bass Tracker, it don't has Power trim, how do you stop the motor from kicking up in rereverse, thank's for you time, Jess
Laddies
Banned
Re: Mercury 35 Elo
On the swival bracket there should be a rev. lock down, it's a set of pawls that engage the tilt pin when the engine is in neutral or rev. If they are stuck or the acttuater spring is broken or the rev lock cam is not working they will not engage on the tilt pin to hold the engine down
Kansas Basser
Re: Mercury 35 Elo
Need some help, went over to mercury parts express, look over the part photo, I have all the parts, it will not work, don't know what to do, thank's for your time, Jess
Laddies
Banned
Re: Mercury 35 Elo
Jess the chances are that someone has taken the unit off and either lost the reverse cam or has it installed in the wrong position on the shift shaft, which means your probably gonig to have to drop the lower unit to ck it - Bob
Laddies
Banned
Re: Mercury 35 Elo
If you look at the parts break down on the lower unit it sets on the shiftshaft part number 43308T1, there is also a spacer washer number 78036 that could be missing
Kansas Basser
Re: Mercury 35 Elo
OK, I see what you are saying, how hard is it to take the leg off, what should I look for when I put the leg back on, I think it had a new water pump put in it in the last year???, would this happen if the water pump was done??? should I put a new impeller in, I want to do this right, thank's
Don S
Re: Mercury 35 Elo
Just a thought here, if you want to do your own maintenance on your motor, you NEED the OEM service manual. All it is, is another tool in your tool box. But without it you may never find the problem. The OEM manual details how it's all put together and adjusted.
Who knows, your reverse lock may be put together correctly, just totally out of adjustment.
As far as the impeller goes, if you don't know how old it is, yes it needs changed. The impellers are inexpensive.
Laddies
Banned
Re: Mercury 35 Elo
Thats probably when it happened, first you really need a manual, that said
Shift the unit in to rev. gear, take a awl and mark the position of the trim tab with a scratch make for reinstallation, remove the trim tab through the hole on the leg right above the tab then remove 1 nut thats under the tab, next remove the nut under the cavitation plate then the 2 nuts from the studs going up through the bottom of the leg 1 on either side at this point the unit should come down. I forgot if the small hose from the lower unit for a speedometer is connected you will have to disconnect it also
Kansas Basser
Re: Mercury 35 Elo
What manual is best, was looking on iboats, was thinking part number 1404 for a manual
Don S
Re: Mercury 35 Elo
The OEM Mercury manual is best, you may even find one on ebay. The Merc PN is 90-42794--1 dated 6/90
Kansas Basser
Re: Mercury 35 Elo
Went down to the Public Library, they have two Manual, not very good one, Clymer Mercury outboard shop manual 2.5-40HP 1972-1989, Seloc Mercury outboard tune-up and repair manual, call around that it, so read them a few time, can't find much about reverse locking, I pull the leg off, I think the reverse cam is not set right, have look at all the parts break down photos, ( all the parts are there ) I have photos, but can't get them to work on here, Thank's for you time, Jess
Laddies
Banned
Re: Mercury 35 Elo
My Mercury manual is # 90-42794-1 most aftermarket manuals are a waste of money
Woops that manual don't have mechanical reverse locks in it I post one - Bob
Kansas Basser
Re: Mercury 35 Elo
this is three Mercury outboard dealer where I live,they can't or won't get me the right manual, will not buy off ebay, so what I'm to do,
Laddies
Banned
Re: Mercury 35 Elo
If a local dealer won't or can't supply you with a manual take your serial number to Mercury Parts Express and they can send one to to you--Bob
Kansas Basser
Re: Mercury 35 Elo
Motor is up and runnig, the reverse lock cam was in 180 deg. off, thank's Laddies, Jess
