1sttimeowner
- Joined
- Jan 4, 2007
- 45
Mark42 said:Hey! Nice Boat! I bet that gel coat will polish up real nice. Should look great after the floor is replaced.
Saskatoon2005 said:Hey,
why don't you use the tags when linking here, so that the actual pictures shows up here and people don't have to search them out....nice looking find you got there though....Good Luck!
Patrick[/quote]
New to all of this computer stuff,how could I do that?I do have other pics to post that could further explain or show what I need to ask about.
Saskatoon2005 said:That boat looks like it has a ton of extra weight added to it. I would cut them all out...grind out the fiberglass that wa attached to them.
Another thing you can do is tack on strips of plywood to the top portion of the stringer, so that the floor has more area to attach too. Also try and do all of the new floor without using any screws...screws makes a place for water to eventually find and get into. Lay new fiberglass mat soaked in resin on top of the stringers (after they are coated in resin and glassed to the hull!) so that the new floor has a good solid connection to the hull. Don't forget about fillets either, you'll need those to get good strong joints. Good Luck!
Patrick
Saskatoon2005 said:Please add a new pic of your cleam slate so I can give you more direction....thanks.
Patrick
Saskatoon2005 said:1sttimeowner,
Check this out, it will definately help you out...
http://forums.iboats.com/bbBoard.cgi?a=viewthread;fid=26;gtid=1262415
Good Luck!
I did look at those pics and yes it does give me better direction.Thank you.
Patrick
