drewpster
- Joined
- Oct 17, 2006
- 2,059
My engine compartment originally vented through vent hoses that opened into an area behind the port and starboard cockpit side panels. The panels were made with cutouts that allowed air to flow behind the panels into open air. I am planning to make new side panels closing off the area and installing access doors for storage. So I need a new way to vent the bilge. I was planning to glass in some doublers on the inside of the hull just below the gunnels and cut in some fancy stainless vents with vent boxes and hoses. The holes for the hoses are already there passing from the cockpit deck through to the bilge area. The problem I have is that on the port side the original vent hole was used to pass the head's holding tank pumpout hose from the tank to the port gunnel where a pumpout fitting is placed.
I have no room to reroute the sanitation hose. You think it would restrict air flow too much if I go ahead and cut in the side vent on the port side and leave the area open rather than using a vent box? Air would have enter through the port vent and pass through the original pass through hole with the sanitation hoses. I know, you have no idea what I am talking about and I need to post pictures. Don't feel bad I am confused myself at this point.
