kynolan2183
Thread starter- Joined
- Mar 3, 2007
- 130
I have an 1984 70 HP evinrude that stalls under very heavy load. IE throttling up while putting it on the trailer.
Boat runs fine and has the top end is 35 mph on a 17 pitch. This is a 17 foot Ozark bass boat
I have checked the spark. Rebuilt and cleaned the carbs. Checked the timing. The pump bulb is fine. Even tried hitting the choke primer to send it some extra fuel. No luck. Floats on the carbs are set correctly.
Questions:
1st The top carb spits a little fuel at idle is this the symtoms of a bad reed or normal?
2nd Any ideas on the stalling thing under heavy load?
3rd Anyone put boysen reeds on this model motor before?
Thanks for your help
Questions:
