2hp overheated - stuck piston rings?
pvcmsc
I'm working on a 1977 2 hp johnson for a friend. Engine may have been ran hot, It's mildly discolored aound the exhaust/head. I checked the compression and it was 80 pounds. I have the same motor myself and it has 95# compression.
Once I saw a motor that had been hot and it had stuck piston rings. Since this motor had really low wear before the "incident" I wandered if there are any shade tree tricks or magic potions that may free a stuck piston ring???
Trust me - it has a new impellor now.
OBJ
Re: 2hp overheated - stuck piston rings?
Welcome to iboats pvcmsc!
How sure of ya' of the "low wear"? Do you know the compression before the incident? What you may try is, do a decarb and see if the compression improves. An engine can live through an overheat if it's not a prolonged overheat condition. Another thing to look at is the head gasket. Could have been damaged during the "incident". Also check the head for warpage.
F_R
It's easy enough to remove the exhaust cover and look. That would be the thin flat plate on the side of the cylinder. Overheat damage usually results in a scored piston, not just rings. But take a look-see.
Use a new gasket to reinstall that plate! If it leaks, it will squirt water into the exhaust ports.
pvcmsc
thanks for both replies - very much appreciated. As for known amount of wear - can't really say for sure, but it's a WV motor and typically they aren't used that much here. Plus paint looks good. Good point though - I could be dead wrong on usage.
If I decarb it and compression goes up - what does it tell me?
I'll do both the decarb and then remove the exhaust plate for a closer inspection.
OBJ
If you decarb and the compression goes up, it could be telling or pointing to some different things like: there has been to heavy a mix in the fuel with oil, the engine is running cold and not coming to temp, poor ignition spark at the plugs. Any of the above or a mix can cause rings to stick. Do the decarb and see what the compression does. Go from there. Let us know your progress.
