40 hp yamaha screams like its out of gear in foward
tnkc
hi all , new boat owner, i have this 40 yamaha and today it ran fine until i went about half throttle at which time it seemed like it was in neutrel. it worked fine at lower speeds any thoughts. i am unsure on year model i am heading out to grab the codes now...
thanks
tnkc
WillyBWright
Re: 40 hp yamaha screams like its out of gear in foward
Sounds like a spun rubber hub in your prop. It can be replaced. Prop rebuilders do that.
tnkc
hey thanks since the prop is showing signs of wear (chipped and dinged) would it be a good idea to just replace it. and if so how do i determine the correct size and pitch..thanks again for the input
Ray Neudecker
Pull it and look at the stamping in the hub if it is a Yamaha prop.
