I've finished installing my rebuilt 73 115hp Johnson and tried to start it today. Needless to say, it didn't go so well.
The engine isn't getting any fire. We noticed metal shavings falling from underneath the flywheel. We took the flywheel off and found two loose bolts. In our hast over Christmas break to install the rebuild, we obviously neglected to inspect the flywheel for loose materials.
Anyway, I cleaned the metal, removed the bolts, and from visual inspection nothing appears to be broken (wires, coils,....including the staator and timing ring). We put it back together, still no spark. I noticed that when I remove a sparkplug and ground the electrode that a very weak spark appears.
What simple tests can I do to verify that the stator/timing ring still function properly? The metal shavings where from the flywheel and were a result of the loose bolts rubbing against the flywheel. The metal did not come from the magnet area, but from the top of the arch.
Before the old motor blew, the ignition seemed to be fine. When we took all of the ignition components off of the powerhead, we kept as much assembled as possible.
