Aluminum Restoration
drewpster
I have to start doing whatever I am going to do to get my aluminum parts restored. The easy (though expensive) way to do it would be to powder coat all the parts and be done with it. However I don't really like the look of white handrails and window frames. Does anyone know of a process that can restore my old aluminum? They include the handrails, window frames ect. ect...
jauguston
Re: Aluminum Restoration
If you want to have your aluminum keep looking good after you restore it one option is to have it powdercoated with clear powder. I have a Eastwood Home Powder Coating system and their clear powder looks pretty good. I have clear powdered some polished parts on an old Sportster I restored. One thing to consider with powder is it has a build up that will increase the diameter of tubes. So if the tubes go through tight fitting stanchion brackets there could be a fit problem.
Jim
iwombat
If your aluminum needs substantial work you can always just paint it with hammerite or similar hammered-metal finish spray paint. Cheap, easy and looks good.
drewpster
I remember seeing a product that is used to protect aluminum for extended periods. I think it is a two part product. I saw it online somewhere. Anbody know it?
I was hoping to finish the aluminum to a satin, rather than high polish. Anybody know a good process to do it.
iwombat
Buffing wheels and air grinder with buffing pad if you want to keep the bare aluminum. It'll take a lot of elbow grease. Once you get it shined up, semichrome metal polish is hands down the best aluminum polish out there.
Eastwood (automotive company) has an excellent selection of polishing, buffing, grinding, and protective coating supplies.
