Yamaha F150 2006 Timing Belt
Bluefish
I would like to take some tension off the timing belt, but I cannot figure out how to back off the tension on the pulley
Thanks
troypolla
Re: Yamaha F150 2006 Timing Belt
I assume that you want to change it. Right? From experience if the belt is fiddled with too much it, and out of tension( to tight.. to loose) it will break. It happened to me on my old car. Yes I fiddled with it. expensive lesson.
Bluefish
Last time out I had some belt squealing when I tensioned the belt it seems to have a off center cam adjustment plus being spring loaded could not figure out how to back it off, from a visual inspection or from the book, and would like to make sure I am in specs
Thanks
JUSTINTIME
do u have the manual?
there is a spring that sets tension
here is how to do it
remove the slack from the belt on the port side of motor by slightly rotating the crank
with the adjuster bolt loose, the spring will put proper amount of tension on the belt
once the slack is removed from the belt, the bolt on the tensioner can be tightened
Bluefish
The question was how you take the tension off the belt, or reset the tensioned pulley.
Thanks
JUSTINTIME
Thanks
read the statment
Propnuts
Thanks
The timing belts on Yamaha 150 4-strokes use a hydraulic type belt tensioner. It is non-adjustable. You release it with a allen key and a stopper\holder tool which will keep it in a relaxed position. If you get to aggressive and impatient with the allen tool, you will strip the area that the allen tool sits in.
When this happens(as the thread starter has probably unfortunatly learned) you will trash the tensioner and it will need to be replaced. When you try and release it you need to put pressure on the allen tool in a slow type movement and wait for the tensioner internal cylinder to collapse .
The spring type with bolt is used on the HPDI belts.
JRJ
Do Suzuki's use chain instead of a "belt"? thanks
Bluefish
No Miss Happes yet just seem like a lot of backpressure, the hydraulic explains that
Thanks
