1965 Gale 12HP Oil/Gas Mix Ratio
codyja
Does anyone know the oil gas mix ratio for this motor? Someone I spoke with about this told me that on this year, I should use 30weight motor oil instead of 2 cycle oil, which I really don't believe. Is there anywhere I can find information out about the motor with my serial number, as it is registered as a '65 but I wanted to confirm. Thanks.
Re: 1965 Gale 12HP Oil/Gas Mix Ratio
mix 50-1 gas to tcw-3 outboard oil. the 30wt was before the invent of tcw-3. most oil bottles have markings on the side so you can measure. and a chart on the back for how much to use
JB
Howdy, cod.
Welcome to iboats. :)
If you post the MODEL number here we can confirm the year of your engine.
Daddy's advice is good for 1964 and later models, but if it is a '63 or earlier you should use a 24:1 mix.
steelespike
To the best of my Knowledge Gales last 12 was in 59 replaced in 60 with a 15D.They ceased production after 63.We can date your motor by the model number and give you basic tune up specs.Fuel mix is 24:1.Use TCW3 rated oil.
just rechecked, Spike is 100% right, use 24-1 if it's gale 12 it's not a 1965, it's 1959 or earlier. i just loked at the manual oil mix and a$$ u me.
pecheux
Hi Y'Awl,
I know I aint gona make friends by saying that ... but it was not 30 weight oil back then ... although it would do the job ... It was 24:1 mix outboard type oil (no color) ... which is no longer available. That oil mixed better with gasoline than 30 weight.
Considering the higher lubricity of the 50:1 type oil many OMC dealers (back then) recommended mixing 32:1 of the blue oil (50:1) with the 24:1 mix type engines.
If that nice 12 hp Gale motor was mine I would mix at 32:1 using synthetic oil.
But It aint mine ... lol
Cheers,
Pecheux
CATransplant
Hi Y'Awl,
Cheers,
Pecheux
No, it's not yours. It's also older than the owner thought. 24:1 is the correct mix for that engine. While it might survive 32:1, at least for a while, it needs the 24:1 mixture to thrive.
Lots of folks are here on this board who date back to those days. They're worth listening to.
They also give excellent advice. Consider this: 24:1 cannot hurt that engine in any way. It won't even cost much more than your recommendation of 32:1. Why on earth would someone want to take a risk with that nice old Gale?
pecheux
Well no offense but I also date back to those years, and yes there are excellent advice given on this board worth reading.
That being said (written) please note that I did NOT recommend a 32:1 mix for the Gale ... I wrote a reference to OMC dealers recommendations to 32:1 mix when the 24:1 type ob oil turned out to be NLA ... and that type of OB oil is still NLA ... and mixing 24:1 with 50:1 type oil is simply not the same mix that motor used to know.
I wrote on this boad in the past regarding the higher lubricity of the 50:1 type oil Vs the 24:1 type oil which explained OMC dealers point of view ... at that time
Yes you"r absolutly right ... 24:1 mix with 50:1 type oil wont hurt the Gale ... but it will run richer in oil that it did when using the old 24:1 type oil ... and may produce more smoke and exhaust port carbon ... but it wont get hurt I agree.
This board allows sharing of knowledge, information, and opinions ... In my previous post I thought I shared information (OMC) and opinion (mine) ... no more.
Cheers,
