What's your best tool?
erikgreen
Try to keep your minds out of the gutter on this one 8)
I've picked up some great suggestions here on tools to use for different jobs during my project. For certain jobs, one type of tool just stands out as the easiest. Since I'm knee deep in the work, I thought I'd ask if anyone has found a particular tool that's the absolute best for a common boat job. I'll start with two I found here:
1) For removing decking, circular saw set to the deck's wood thickness - cuts the deck without serious stringer harm, is fast, and keeps dust/chips to a minimum. Downside is, can't fit in corners easily
2) Electric chainsaw for removing foam - slices the foam into 6x6 blocks, one good pry and the block comes out neatly right down to the glass... no chipping the foam out piece by piece. Makes a different sound when you hit glass, so you can avoid cutting your hull, even when the blade is buried in foam
Boomyal
Re: What's your best tool?
Impossible for me to say EG. When I did my resto, I had every tool in the tool cabinet strewn about the work area. Most all were indispensable for the perticular application I got them out for.
One diffence I had with your experience, I used a battery powered reciprocating saw to slice the foam into blocks. I ground the tip of the blade round so that if I did kiss the hull I could feel it very quickly and it would do no damage.
jddenham
Air compressor is one of the most important tools in my opinion. You can buy many different attachments, save money over electric, and have a platform for spraying. Not to mention an air gun to blow away debris.
andy6374
-4 1/2" angle grinder
-angle die grinder with drum sanding heads and 3M roloc attachments
OhioLowell
Ruger Black Hawk in 44mag. This is the tool that will get the job done when no others will! LOL8)
I'd have to say the tools that get the most use around here are my craftsman battery tool set. (circular saw, saw zall, light, drill.....By far the best Christmas present I've ever gotten)
After that as far as the boat goes, a good 4.5" grinder, with good 60grit discs, and a good cupped wire wheel.
Best,
Lowell
Zetman
iboat site and this computer thingy I'm looking at..Has been the best tool so far8)
i agree with Ohio Lowell, i now have a complete set of Ryobi, 18 volt tools, drill, flash light, circular saw, sawzall, jig saw, chain saw, screw gun. i also have 2 double chargers, and numerous batteries. heck with the extension cord. also agree with air compressor.
tommays
Rigid 44-S baby :) cant beat in those tight places
Tommays
iwombat
Fasteners and salt water?
Gotta have one of these eventually:
AKA - The blue wrench
Scaaty
Best damn tool in the shed when things don't go as planned..
Yacht Dr.
all kidding aside..i woud say ..
my Mac 7' grinder/polisher ( will fit grinding wheels for major glass jobs down to pollishing pads..variable speed trigger and dial speed )
but out of all..and above all tools that has made me the most amount of time and cost..it would have to be the Porter Cable 6" DA.. you can sand sand sand..more dust..more cash lol...( If you dont have this tool..then you should get one..and learn how to use it..)
YD
sbklf
Variable speed right angle drill w/4" sanding pad and coarse disc. I added a backing plate behind the rubber pad for backbone. I like it for tight spots and at low rpm the dust is minimal.
Mark42
Best tool: Rotary Sander/Buffer.
Second best tool: Big big big socket set
Third best tool: Circle clip pliers.
Scaaty
This is just maybe 10 percent of my home shop. Probably not a home shop tool known to man I don't own. This is just the Lathe/Drill, Welding booth part. Best tool is massive lighting and 90% more bench space than you think you need..and cordless ANYTHING!.
Scatty, if your like me, you walk around looking for something, saying i know i have one of those, finely settle for another tool, only to find the one you wanted, after your done.
Scaaty
HA! 90% of what I own was bought AFTER I discovered it was what I needed. Then ya never need it again! But the neighbors sure love me!
