question about slip?
troypolla
I was doing some calculating, and this shows my slip to be 0.008310. This is in percent right? Or should I move the decimel over 2. But even then it would be less than 1% slip.
5800 rpm at wot
38mph
2.15gear
Re: question about slip?
You're probably Off a Couple of decimal points.....
Anything from 10%,+ Under is considered Ideal.............
troypolla
verified with gps. forgot to add that.
72SideWinderSS
If your prop is cupped, you need to add one inch to the actual pitch of the prop. i.e. 15p + 1 for cup = 16p
Running the numbers with 16p = 7%
troypolla
Thats it. Thanks. It makes sense now.
